メインコンテンツにスキップ
RCA 8 Apollo Camera Replacement
必要な工具と部品
  1. RCA 8 Apollo Camera Replacement, Back Panel: 手順 1、 1の画像 1
    • Before you begin, discharge your tablet battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your tablet before beginning to disassemble.
  2. RCA 8 Apollo Camera Replacement: 手順 2、 2の画像 1 RCA 8 Apollo Camera Replacement: 手順 2、 2の画像 2
    • Insert an iFixit opening tool into the gap between the tablet and back panel.
    • Using a combination of iFixit opening tools and iFixit opening picks, pry the tablet upward around its perimeter to release it from the plastic rear case.
    • If inserted too far, an opening pick can damage your device. It is helpful to mark the edge with an opening pick, or opening tool at a depth that will not damage the inner contents of the tablet.
  3. RCA 8 Apollo Camera Replacement: 手順 3、 2の画像 1 RCA 8 Apollo Camera Replacement: 手順 3、 2の画像 2
    • Disconnect the red and black speaker wires from the tablet.
    • The front and back of the tablet will be disconnected.
  4. RCA 8 Apollo Camera Replacement, Display Assembly: 手順 4、 3の画像 1 RCA 8 Apollo Camera Replacement, Display Assembly: 手順 4、 3の画像 2 RCA 8 Apollo Camera Replacement, Display Assembly: 手順 4、 3の画像 3
    • Release the gold and black tab from the battery that's attached to a gray wire. The gold tab is held down by an adhesive; pull it until the adhesive releases.
    • Remove the yellow tape that is around the battery.
    • Unlock the ZIF socket and detach the display data interconnect cable from the front panel assembly.
    • If the connector is misaligned, the pins can bend, causing permanent damage.
  5. RCA 8 Apollo Camera Replacement: 手順 5、 1の画像 1
    • Remove the three screws from the motherboard using a Phillips screwdriver.
  6. RCA 8 Apollo Camera Replacement: 手順 6、 1の画像 1
    • Remove the battery and motherboard together from the tablet.
    • If the tablet needs a battery replacement, disconnect the battery and replace it with a new one.
    • The battery might be glued down; you will just need to slowly remove the battery as the adhesive releases.
  7. RCA 8 Apollo Camera Replacement, Camera: 手順 7、 2の画像 1 RCA 8 Apollo Camera Replacement, Camera: 手順 7、 2の画像 2
    • Remove the front facing and back facing cameras from the top of the tablet.
終わりに
作成者
1人の作成者と共同作成されました。
Chantel Pfiefer
メンバー登録日: 04/15/24
219 ポイント
2のガイドは作成済み
チーム
Casper College, Team 1-1, Lareau Spring 2024 Casper College, Team 1-1, Lareau Spring 2024人のメンバー
CASC-LAREAU-S24S1G1
3 メンバー
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 7
今までの合計 83
