メインコンテンツにスキップ
RCA 22” DECK215R HDTV Screen Replacement
必要な工具と部品
  1. RCA 22” DECK215R HDTV Screen Replacement, Removing the Stand: 手順 1、 2の画像 1 RCA 22” DECK215R HDTV Screen Replacement, Removing the Stand: 手順 1、 2の画像 2
    • Before disassembling your television, ensure that all cables are unplugged from their power source to avoid serious injury or death from electrocution.
    • Lay the TV flat with the screen facing down.
    • Remove the four, 12mm Phillips #2 screws from the back of the TV stand. Support the TV from underneath as you remove the screws, so the bottom does not fall on the table.
    • Remove the stand by lifting it away from the TV's backing.
  2. RCA 22” DECK215R HDTV Screen Replacement, Removing the Back Panel: 手順 2、 2の画像 1 RCA 22” DECK215R HDTV Screen Replacement, Removing the Back Panel: 手順 2、 2の画像 2
    • Remove the twelve, 6mm Phillips #2 screws from the middle of the TV's rear casing.
    • Remove the seven, 9mm Phillips #2 screws from the outer edge of the TV's rear casing.
    • While holding the screen down, pull the back panel up slowly, ensuring that you do not forcibly disconnect the remaining ribbon cable.
  3. RCA 22” DECK215R HDTV Screen Replacement, Locate Pin: 手順 3、 1の画像 1
    • Position the television to where the back panel is resting on the table and the screen is vertical.
    • Peel the tape covering the ribbon cable horizontally.
  4. RCA 22” DECK215R HDTV Screen Replacement: 手順 4、 3の画像 1 RCA 22” DECK215R HDTV Screen Replacement: 手順 4、 3の画像 2 RCA 22” DECK215R HDTV Screen Replacement: 手順 4、 3の画像 3
    • Pinch the clamps on both sides of the ribbon cable casing to detach it from the screen panel.
    • Remove the screen to isolate the back panel.
  5. RCA 22” DECK215R HDTV Screen Replacement, Remove Screws: 手順 5、 1の画像 1
    • Remove the four, 12mm Phillips #2 screws from the outer edge of the back of the screen panel.
  6. RCA 22” DECK215R HDTV Screen Replacement, Remove the Screen from the Frame: 手順 6、 1の画像 1
    • Lift up the screen to remove it from the plastic frame.
  7. RCA 22” DECK215R HDTV Screen Replacement, Remove Brackets from the Side of the Screen: 手順 7、 1の画像 1
    • Remove the two, 5mm Phillips #2 screws from the metal bracket attached to the horizontal side of the TV and take the bracket off.
    • Repeat this process on the other side of the TV to completely isolate the screen.
終わりに
2 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Patrick Soper
メンバー登録日: 01/15/15
691 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 70-2, Forte Winter 2015 Cal Poly, Team 70-2, Forte Winter 2015人のメンバー
CPSU-FORTE-W15S70G2
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 1,282
