このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Lay the TV flat with the screen facing down.
Remove the four, 12mm Phillips #2 screws from the back of the TV stand. Support the TV from underneath as you remove the screws, so the bottom does not fall on the table.
Remove the stand by lifting it away from the TV's backing.
この手順は未翻訳です。 翻訳を手伝う。
Remove the twelve, 6mm Phillips #2 screws from the middle of the TV's rear casing.
Remove the seven, 9mm Phillips #2 screws from the outer edge of the TV's rear casing.
While holding the screen down, pull the back panel up slowly, ensuring that you do not forcibly disconnect the remaining ribbon cable.
