メインコンテンツにスキップ
RCA 10 Viking Pro RCT6K03W13 Battery Replacement
必要な工具と部品
  1. RCA 10 Viking Pro RCT6K03W13 Battery Replacement, Backplate: 手順 1、 3の画像 1 RCA 10 Viking Pro RCT6K03W13 Battery Replacement, Backplate: 手順 1、 3の画像 2 RCA 10 Viking Pro RCT6K03W13 Battery Replacement, Backplate: 手順 1、 3の画像 3
    • Remove the three Phillips #00 screws at the bottom of the device.
  2. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: 手順 2、 2の画像 1 RCA 10 Viking Pro RCT6K03W13 Battery Replacement: 手順 2、 2の画像 2
    • Remove the two Phillips #00 screws to the left and right of the keyboard connector.
  3. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: 手順 3、 1の画像 1
    • Pull on one of the bottom corners to begin to pull off the back plate.
  4. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: 手順 4、 2の画像 1 RCA 10 Viking Pro RCT6K03W13 Battery Replacement: 手順 4、 2の画像 2
    • Work around the outside of the chassis, using the spudger to pry the backplate off.
    • After doing this for about half the device, the backplate should pop right off.
  5. RCA 10 Viking Pro RCT6K03W13 Battery Replacement, Battery: 手順 5、 1の画像 1
    • Remove the tape over the connectors on the motherboard and other side of the battery.
  6. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: 手順 6、 1の画像 1
    • Disconnect the red and black keyboard wires connecting the battery to the motherboard.
  7. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: 手順 7、 1の画像 1
    • Disconnect the black ribbon cable running over the battery. Flip up the black clamp and pull the cable out.
  8. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: 手順 8、 2の画像 1 RCA 10 Viking Pro RCT6K03W13 Battery Replacement: 手順 8、 2の画像 2
    • Remove the cable over the battery connecting the motherboard and the power connector.
    • Flip up the black clamp and pull the cable out.
  9. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: 手順 9、 2の画像 1 RCA 10 Viking Pro RCT6K03W13 Battery Replacement: 手順 9、 2の画像 2
    • Pull out battery. It is taped to the device so it is safe to pull out.
    • Look for damage to the battery. If damaged, make sure to not get any acid on your fingers.
終わりに
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Ryan Wickett
メンバー登録日: 10/25/19
632 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G8, O'Connell Fall 2019 UMass Dartmouth, Team S1-G8, O'Connell Fall 2019人のメンバー
UMASSD-O'CONNELL-F19S1G8
3 メンバー
4のガイドは作成済み
4 件のコメント
Where can I get the battery for this?
Justin - 返信
You can get a battery from Amazon or Walmart.com your wellcome ?
GLENDA Vandergrift -
How much voltage should the battery put out in order for the tablet to turn on?
Jesus Rios - 返信
How much
How much
jennylyne_08 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 36
今までの合計 3,058
