はじめに
This replacement guide will teach someone how to successfully remove the digital battery from the Quiksilver The Fifty50 sports watch. Before getting started make sure to grab the tools necessary and at least skim the instructions once to understand what it will look like while you are replacing the digital battery, that way there will be no surprises as you go through the steps.
必要な工具と部品
Remove the four 1.1 mm screws holding the back panel in place using the Phillips #00 screwdriver.
Using the Phillips #00 screwdriver, remove the two 1 mm screws holding the circuit board to the device.
Using the Phillips #00 screwdriver, remove the 1.1 mm screw that is holding the digital battery holder in place.
