メインコンテンツにスキップ
はじめに
This replacement guide will teach someone how to successfully remove the digital battery from the Quiksilver The Fifty50 sports watch. Before getting started make sure to grab the tools necessary and at least skim the instructions once to understand what it will look like while you are replacing the digital battery, that way there will be no surprises as you go through the steps.
パーツ
パーツは指定されていません。
  1. Quiksilver The Fifty50 Digital Battery Replacement, Strap: 手順 1、 2の画像 1 Quiksilver The Fifty50 Digital Battery Replacement, Strap: 手順 1、 2の画像 2
    • Place the watch (face down) on a solid surface.
    • Carefully use the screwdriver and push in one side of the strap.
    • Slowly remove the strap by pushing back one of the hidden metallic holders for the strap.
    • If you are having difficulty trying to take off the strap, feel free to use a 3.5 flat head screw driver, or any kind of tool that make this step easier.
  2. Quiksilver The Fifty50 Digital Battery Replacement: 手順 2、 2の画像 1 Quiksilver The Fifty50 Digital Battery Replacement: 手順 2、 2の画像 2
    • Gently pull the pin out of the strap.
    • Carefully handle the small metallic holder, as they are sharp and may be difficult to locate if lost.
  3. Quiksilver The Fifty50 Digital Battery Replacement, Back Panel: 手順 3、 2の画像 1 Quiksilver The Fifty50 Digital Battery Replacement, Back Panel: 手順 3、 2の画像 2
    • Remove the four 1.1 mm screws holding the back panel in place using the Phillips #00 screwdriver.
  4. Quiksilver The Fifty50 Digital Battery Replacement: 手順 4、 1の画像 1
    • Carefully separate the panel off of the watch.
    • Careful not to lose the four 1.1 mm screw or else the back panel will not be able to put back.
  5. Quiksilver The Fifty50 Digital Battery Replacement, Analog Battery: 手順 5、 2の画像 1 Quiksilver The Fifty50 Digital Battery Replacement, Analog Battery: 手順 5、 2の画像 2
    • Carefully lift the white plastic circular out of the watch.
  6. Quiksilver The Fifty50 Digital Battery Replacement: 手順 6、 3の画像 1 Quiksilver The Fifty50 Digital Battery Replacement: 手順 6、 3の画像 2 Quiksilver The Fifty50 Digital Battery Replacement: 手順 6、 3の画像 3
    • Remove the four 1.1 mm screws located on the metallic holder using the Phillips #00 screwdriver.
  7. Quiksilver The Fifty50 Digital Battery Replacement: 手順 7、 3の画像 1 Quiksilver The Fifty50 Digital Battery Replacement: 手順 7、 3の画像 2 Quiksilver The Fifty50 Digital Battery Replacement: 手順 7、 3の画像 3
    • Remove the large circular Analog battery.
  8. Quiksilver The Fifty50 Digital Battery Replacement, Circuit Board: 手順 8、 2の画像 1 Quiksilver The Fifty50 Digital Battery Replacement, Circuit Board: 手順 8、 2の画像 2
    • Using the Phillips #00 screwdriver, remove the two 1 mm screws holding the circuit board to the device.
  9. Quiksilver The Fifty50 Digital Battery Replacement: 手順 9、 1の画像 1
    • Remove the green circular chip using a pair of tweezers.
  10. Quiksilver The Fifty50 Digital Battery Replacement, Digital Battery: 手順 10、 2の画像 1 Quiksilver The Fifty50 Digital Battery Replacement, Digital Battery: 手順 10、 2の画像 2
    • Using the Phillips #00 screwdriver, remove the 1.1 mm screw that is holding the digital battery holder in place.
  11. Quiksilver The Fifty50 Digital Battery Replacement: 手順 11、 1の画像 1
    • Use the magnetic pick-up tool to remove the small screw.
    • Careful to not lose this screw because it is crucial for putting the watch back.
  12. Quiksilver The Fifty50 Digital Battery Replacement: 手順 12、 1の画像 1
    • Lift up the battery holder.
  13. Quiksilver The Fifty50 Digital Battery Replacement: 手順 13、 1の画像 1
    • Remove the digital battery from the socket.
終わりに
Sue Giske
メンバー登録日: 2019年07月16日
622 ポイント
5のガイドは作成済み
チーム
UW Tacoma, Team S1-G4, Liner Summer 2019 UW Tacoma, Team S1-G4, Liner Summer 2019人のメンバー
UWT-LINER-SU19S1G4
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 39
今までの合計 986
