この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If your Quiksilver The Fifty50 sports watch has not been turning on or seems to be having battery issues this guide will successfully teach someone how to remove the analog battery. Before getting started make sure to grab the tools necessary and at least skim the instructions once to understand what it will look like while you are replacing the battery, that way there will be no surprises as you go through the steps.
必要な工具と部品
Remove the four 1.1 mm screws holding the back panel in place using the Phillips #00 screwdriver.
