メインコンテンツにスキップ
Quiksilver The Fifty50 Analog Battery Replacement
必要な工具と部品
  1. Quiksilver The Fifty50 Analog Battery Replacement, Strap: 手順 1、 2の画像 1 Quiksilver The Fifty50 Analog Battery Replacement, Strap: 手順 1、 2の画像 2
    • Place the watch (face down) on a solid surface.
    • Carefully use the screwdriver and push in one side of the strap.
    • Slowly remove the strap by pushing back one of the hidden metallic holders for the strap.
    • If you are having difficulty trying to take off the strap, feel free to use a 3.5 flat head screw driver, or any kind of tool that make this step easier.
  2. Quiksilver The Fifty50 Analog Battery Replacement: 手順 2、 2の画像 1 Quiksilver The Fifty50 Analog Battery Replacement: 手順 2、 2の画像 2
    • Gently pull the pin out of the strap.
    • Carefully handle the small metallic holder, as they are sharp and may be difficult to locate if lost.
  3. Quiksilver The Fifty50 Analog Battery Replacement, Back Panel: 手順 3、 2の画像 1 Quiksilver The Fifty50 Analog Battery Replacement, Back Panel: 手順 3、 2の画像 2
    • Remove the four 1.1 mm screws holding the back panel in place using the Phillips #00 screwdriver.
  4. Quiksilver The Fifty50 Analog Battery Replacement: 手順 4、 1の画像 1
    • Carefully separate the panel off of the watch.
    • Careful not to lose the four 1.1 mm screw or else the back panel will not be able to put back.
  5. Quiksilver The Fifty50 Analog Battery Replacement, Analog Battery: 手順 5、 2の画像 1 Quiksilver The Fifty50 Analog Battery Replacement, Analog Battery: 手順 5、 2の画像 2
    • Carefully lift the white plastic circular out of the watch.
  6. Quiksilver The Fifty50 Analog Battery Replacement: 手順 6、 3の画像 1 Quiksilver The Fifty50 Analog Battery Replacement: 手順 6、 3の画像 2 Quiksilver The Fifty50 Analog Battery Replacement: 手順 6、 3の画像 3
    • Remove the four 1.1 mm screws located on the metallic holder using the Phillips #00 screwdriver.
  7. Quiksilver The Fifty50 Analog Battery Replacement: 手順 7、 3の画像 1 Quiksilver The Fifty50 Analog Battery Replacement: 手順 7、 3の画像 2 Quiksilver The Fifty50 Analog Battery Replacement: 手順 7、 3の画像 3
    • Remove the large circular Analog battery.
終わりに
作成者
4人の作成者と共同で作成されました。
Sue Giske
メンバー登録日: 07/16/19
622 ポイント
5のガイドは作成済み
チーム
UW Tacoma, Team S1-G4, Liner Summer 2019 UW Tacoma, Team S1-G4, Liner Summer 2019人のメンバー
UWT-LINER-SU19S1G4
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 647
