メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Quasar Microwave Capacitor Replacement
必要な工具と部品
  1. Quasar Microwave Capacitor Replacement, Disassembling Quasar Microwave Outer Cover: 手順 1、 1の画像 1
    • Disconnect the power supply cord from the outlet.
    FixBotに聞いてみる
    コメントを追加
  2. Quasar Microwave Capacitor Replacement: 手順 2、 2の画像 1 Quasar Microwave Capacitor Replacement: 手順 2、 2の画像 2
    • Remove the eight screws holding the wood-patterned cover to the microwave frame.
    • The first four screws are located on either side of the microwave front.
    FixBotに聞いてみる
    コメントを追加
  3. Quasar Microwave Capacitor Replacement: 手順 3、 2の画像 1 Quasar Microwave Capacitor Replacement: 手順 3、 2の画像 2
    • Remove the additional four screws securing the wood-paneled case to the microwave frame.
    FixBotに聞いてみる
    コメントを追加
  4. Quasar Microwave Capacitor Replacement: 手順 4、 3の画像 1 Quasar Microwave Capacitor Replacement: 手順 4、 3の画像 2 Quasar Microwave Capacitor Replacement: 手順 4、 3の画像 3
    • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
    • Lift the case upward slowly until the case is free of the microwave.
    FixBotに聞いてみる
    コメントを追加
  5. Quasar Microwave Capacitor Replacement, Capacitor: 手順 5、 2の画像 1 Quasar Microwave Capacitor Replacement, Capacitor: 手順 5、 2の画像 2
    • Old electronics collect dust, no matter if they are in active use or being stored. It is recommended to clear out some of the dust prior to affecting any complicated repairs. Use compressed air, and wear a dust mask and goggles. Always use precaution when working with old electronics.
    • The capacitor stores a small amount of electrical energy. Discharge capacitor by placing a screw driver across the terminals. Use a screwdriver with a non-metallic handle and a shaft that is longer than 4” (10.75mm) Touch the metal shaft of the screwdriver simultaneously to both metal terminals of the capacitor. There should be a spark.
    • If the capacitor sparks, you can stop reading here. The spark indicates that the capacitor is working properly. If the capacitor does not spark, read on to Step 6.
    FixBotに聞いてみる
    コメントを追加
  6. Quasar Microwave Capacitor Replacement: 手順 6、 1の画像 1
    • Place the multimeter on resistance mode and test the resistance of the capacitor.
    • If the resistance increases/decreases, the capacitor is working fine. If the resistance of the capacitor reads 0 or over several kilo ohms, the capacitor needs to be replaced.
    FixBotに聞いてみる
    コメントを追加
  7. Quasar Microwave Capacitor Replacement: 手順 7、 3の画像 1 Quasar Microwave Capacitor Replacement: 手順 7、 3の画像 2 Quasar Microwave Capacitor Replacement: 手順 7、 3の画像 3
    • Tip the microwave back so it is lying face up. This allows access to the screws beneath the transformer.
    FixBotに聞いてみる
    コメントを追加
  8. Quasar Microwave Capacitor Replacement: 手順 8、 2の画像 1 Quasar Microwave Capacitor Replacement: 手順 8、 2の画像 2
    • Locate the transformer. The capacitor cannot be removed without removing the transformer first.
    • Locate and unhook all wires connecting the transformer to the rest of the microwave.
    • Take note of where each wire connects before disconnecting. Wiring a microwave incorrectly can cause serious damage.
    FixBotに聞いてみる
    コメントを追加
  9. Quasar Microwave Capacitor Replacement: 手順 9、 1の画像 1
    • Remove the four exterior screws securing the transformer to the microwave frame.
    FixBotに聞いてみる
    コメントを追加
  10. Quasar Microwave Capacitor Replacement: 手順 10、 3の画像 1 Quasar Microwave Capacitor Replacement: 手順 10、 3の画像 2 Quasar Microwave Capacitor Replacement: 手順 10、 3の画像 3
    • Remove the transformer.
    FixBotに聞いてみる
    コメントを追加
  11. Quasar Microwave Capacitor Replacement: 手順 11、 2の画像 1 Quasar Microwave Capacitor Replacement: 手順 11、 2の画像 2
    • The metal band locking the capacitor in place can now be accessed. Locate and remove the screw securing the the metal band.
    • Lift the metal band off the capacitor.
    FixBotに聞いてみる
    コメントを追加
  12. Quasar Microwave Capacitor Replacement: 手順 12、 3の画像 1 Quasar Microwave Capacitor Replacement: 手順 12、 3の画像 2 Quasar Microwave Capacitor Replacement: 手順 12、 3の画像 3
    • Remove the capacitor.
    FixBotに聞いてみる
    コメントを追加
  13. Quasar Microwave Capacitor Replacement: 手順 13、 1の画像 1
    • You can now install a replacement capacitor.
    • Repeat all steps in reverse order to install a capacitor in a Quasar Microwave MQ7774XW (1984).
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
8人の作成者と共同で作成されました。
Michael
メンバー登録日: 09/26/12
237 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 2-12, Propen Fall 2012 Cal Poly, Team 2-12, Propen Fall 2012人のメンバー
CPSU-PROPEN-F12S2G12
3 メンバー
18のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 21
過去 30 日: 68
今までの合計 7,570
