メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Quantum View 10.1 Battery Replacement
必要な工具と部品
  1. Quantum View 10.1 Battery Replacement, Open Quantum View case: 手順 1、 1の画像 1
    • Start by turning the tablet over with the screen down. Carefully use a plastic opening tool to pry the cover off. Start from the corner opposite the hibernate button.
    FixBotに聞いてみる
  2. Quantum View 10.1 Battery Replacement, Removing the electrical tape and magnets.: 手順 2、 2の画像 1 Quantum View 10.1 Battery Replacement, Removing the electrical tape and magnets.: 手順 2、 2の画像 2
    • Pick up the magnets from the bottom edge of the tablet next to the keyboard connection and put them in a place that they will not get lost. Then carefully remove all 4 strips of electrical tape.
    FixBotに聞いてみる
  3. Quantum View 10.1 Battery Replacement, Unhooking the battery: 手順 3、 2の画像 1 Quantum View 10.1 Battery Replacement, Unhooking the battery: 手順 3、 2の画像 2
    • Using a small plastic opening tool; genteelly pull the connection off of the motherboard.
    FixBotに聞いてみる
終わりに
作成者
4人の作成者と共同で作成されました。
stephen Munchinsky
メンバー登録日: 04/01/17
801 ポイント
7のガイドは作成済み
チーム
Gateway Community College Team 1 BPC270 36301 Gateway Community College Team 1 BPC270 36301人のメンバー
Community
4 メンバー
7のガイドは作成済み
4件のガイドコメント
How do I find a replacement battery?
Chris Clayton - 返信 共有
Seems finding the right battery is a problem
where can I find a replacement battery and screen for this i only have the motherboard lying around and i really want to repair it so i can access old data
aabel joby - 返信 共有
the only way is to desolder the old bms from the battery and solder a new battery with the same dimensions, voltage, capacity etc. they are easy to find on aliexpress, i replaced my battery this way, but be very careful with batteries, or if you have enough soldering skills you can solder a usb connector to the barrel jack on the motherboard for a quick fix, gonna try this myself later
if you have the original power supply you can use it, also this tablet doesnt support charging trough micro usb, its for data only
mishaneyu - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 50
今までの合計 1,372
