はじめに
In order to get to the speakers, the battery, back panel, and logic board need to be disassembled first.
必要な工具と部品
Use the Phillips PH1 screwdriver to unscrew the five 4x2.5mm screws that hold the back cover.
Start by disconnecting the cables attached to the motherboard
use the spudger to lift the connectors vertically off. They should pop off with relative ease
The last connector has a yellow tab. Pull up on the tab until the small metal catch lifts up. Then pull straight back to remove the connector from its socket.
終わりに
