メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement
必要な工具と部品
  1. Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement, Battery: 手順 1、 2の画像 1 Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement, Battery: 手順 1、 2の画像 2
    • Locate your device.
    • Flip device onto its back.
  2. Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement: 手順 2、 1の画像 1
    • Remove the tablet's back cover.
  3. Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement: 手順 3、 1の画像 1
    • Locate the battery and remove it.
    • If you wish to replace the battery you can do so here.
  4. Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement, Back Panel: 手順 4、 2の画像 1 Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement, Back Panel: 手順 4、 2の画像 2
    • Use the Phillips PH1 screwdriver to unscrew the five 4x2.5mm screws that hold the back cover.
  5. Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement: 手順 5、 1の画像 1
    • Pop out the back cover.
  6. Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement, Motherboard: 手順 6、 3の画像 1 Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement, Motherboard: 手順 6、 3の画像 2 Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement, Motherboard: 手順 6、 3の画像 3
    • Start by disconnecting the cables attached to the motherboard
    • use the spudger to lift the connectors vertically off. They should pop off with relative ease
    • The last connector has a yellow tab. Pull up on the tab until the small metal catch lifts up. Then pull straight back to remove the connector from its socket.
  7. Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement: 手順 7、 1の画像 1
    • Using the Phillips PH1, remove all 6 of the 3x2.5mm screws (circled in red) holding the motherboard in place.
  8. Qualcomm Snapdragon 800 Mobile Development Motherboard Replacement: 手順 8、 1の画像 1
    • Using the spudger lift the motherboard out of the tablet frame.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Jason
メンバー登録日: 09/25/17
152 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S2-G6, Thompson Fall 2017 University of North Texas, Team S2-G6, Thompson Fall 2017人のメンバー
UNT-THOMPSON-F17S2G6
3 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 17
過去 30 日: 37
今までの合計 758
