はじめに
Prior to this step, remove battery, phone backing, and motherboard
  1. Unscrew the back battery plate from the phone using a T6 Torx screwdriver.
    • Unscrew the back battery plate from the phone using a T6 Torx screwdriver.
    • The screw does not need to be removed completely, the back battery plate will unhinge from the phone.
  2. Using the T6 Torx screwdriver, remove the two screws located at the bottom of the back of the phone. Find the seam between the front and back of the phone
    • Using the T6 Torx screwdriver, remove the two screws located at the bottom of the back of the phone.
    • Find the seam between the front and back of the phone
    • Pry the seam open using a plastic opening tool, or your fingers.
    • Some force is required
  3. Locate the four metal clips holding the motherboard onto the phone.
    • Locate the four metal clips holding the motherboard onto the phone.
    • Pull the clips away from the motherboard while lifting the motherboard out of the case.
    • The motherboard is attached to the case by a fragile cable, do not apply any stress to the cable.
  4. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  5. Place the motherboard down so that the screen is facing up. Grab the small brown connector plug at the sides with a fingernail or tweezers and flip it up.
    • Place the motherboard down so that the screen is facing up.
    • Grab the small brown connector plug at the sides with a fingernail or tweezers and flip it up.
    • Locate, but do not disconnect, the four screen clips.
  6. Flip the motherboard over so that the screen is facing down. Again, be careful not to put stress on the speaker cable.
    • Flip the motherboard over so that the screen is facing down.
    • Again, be careful not to put stress on the speaker cable.
  7. Remove keypad circuit board by lifting up circuit board while pulling clip.
    • Remove keypad circuit board by lifting up circuit board while pulling clip.
    • Remove rubber keypad
    • Insert new rubber keypad.
まとめ
Colin Packard
メンバー登録日: 2014年09月30日
101 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-4, Buehl Fall 2014 Ohio State, Team 1-4, Buehl Fall 2014人のメンバー
OSU-BUEHL-F14S1G4
4 メンバー
10のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 125
