はじめに
Today We Will Go Over How To Replace Your Flipper Zero Shell With A Transparent One. This One In Particular Is The Screen Delete Version Which Looks Much Better Than The Non-Screen Delete Version. This Is Also A Good Option If You Cracked Your Flipper Zero Screen, Because Flipper Zero Does Not Offer Screen Replacements.
必要な工具と部品
Use A PH0 Screwdriver To Open/Remove The Back Part Of The Shell.
Using Your Fingernail, Spudger, Guitar Pick, Or Any Other Prying Tool, Take Off The Back Shell.
Using Your PH0 Screwdriver Unscrew The Two Short Screws Holding The Internals Down To The Shell.
Put Your Flipper's Internals Into The New Shell.
Screw The Three Short Screws Back Into Place.
Using Your, Spudger, Guitar Pick, Flathead Screwdriver, Or Any Other Prying Tool, Take Off The NFC Board
Put The Two Shells Together And Then Insert The Four Long Screws Into The Screw Holes And Tighten Them.
3 の人々がこのガイドを完成させました。
