1. Remove the top bar by removing the 5cm hex T10 screws on the back of the device as shown. Then gently pull off the top bar from the main component. Remove the top bar by removing the 5cm hex T10 screws on the back of the device as shown. Then gently pull off the top bar from the main component. Remove the top bar by removing the 5cm hex T10 screws on the back of the device as shown. Then gently pull off the top bar from the main component.
    • Remove the top bar by removing the 5cm hex T10 screws on the back of the device as shown. Then gently pull off the top bar from the main component.
  2. Remove the 1.2 cm hex T9 screws and gently open up the device. Remove the 1.2 cm hex T9 screws and gently open up the device.
    • Remove the 1.2 cm hex T9 screws and gently open up the device.
  3. Flip the top bar over and using a #00 phillips head screwdriver, remove the five 7mm screws holding the bar together. Flip the top bar over and using a #00 phillips head screwdriver, remove the five 7mm screws holding the bar together.
    • Flip the top bar over and using a #00 phillips head screwdriver, remove the five 7mm screws holding the bar together.
  4. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  5. Carefully pry off the plastic panel, revealing the motherboard. Carefully pry off the plastic panel, revealing the motherboard.
    • Carefully pry off the plastic panel, revealing the motherboard.
  6. Remove the two 7mm screws holding the motherboard in place with a phillips head screwdriver size #00. Remove the two 7mm screws holding the motherboard in place with a phillips head screwdriver size #00.
    • Remove the two 7mm screws holding the motherboard in place with a phillips head screwdriver size #00.
  7. To release the motherboard from its plastic housing, first pull the plastic light covers up and away from the device. To release the motherboard from its plastic housing, first pull the plastic light covers up and away from the device.
    • To release the motherboard from its plastic housing, first pull the plastic light covers up and away from the device.
  8. Heat the solder on the underside of the affected light to remove and replace it using tweezers. Check out this helpful guide for some soldering and desoldering tips.
    • Heat the solder on the underside of the affected light to remove and replace it using tweezers.
    • Check out this helpful guide for some soldering and desoldering tips.
まとめ
Brian Maulucci
メンバー登録日: 2018年09月10日
581 ポイント
4のガイドは作成済み
チーム
Appalachian State University, Team S2-G6, Menagarishvili Fall 2018 Appalachian State University, Team S2-G6, Menagarishvili Fall 2018人のメンバー
APSU-MENAGARISHVILI-F18S2G6
3 メンバー
4のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 64
