メインコンテンツにスキップ
Puritan Bennett 840 BPS Battery Replacement
医療機器
この修理ガイドは医療機器メーカーからの是認を得ておらず、iFixitと医療機器メーカーは提携していません。
  1. Puritan Bennett 840 BPS Battery Replacement, BPS Battery: 手順 1、 2の画像 1 Puritan Bennett 840 BPS Battery Replacement, BPS Battery: 手順 1、 2の画像 2
    • Before beginning, ensure that the battery is drained and the ventilator is not connected to a power source.
    • Locate the breath delivery unit (BDU) shelf on the ventilator.
    • Locate the battery indicator label on the shelf to determine whether the BPS battery holds a one-hour or four-hour charge - the default for this guide is a four-hour battery.
  2. Puritan Bennett 840 BPS Battery Replacement: 手順 2、 1の画像 1
    • Grasp the sides of the front bezel of the BPU and gently spread them away from the ventilator.
    • Pull the bezel outward to remove it from the cart.
    • Use a Phillips screwdriver to remove the two screws that connect the BPS to the BDU shelf at the back of the cart.
  3. Puritan Bennett 840 BPS Battery Replacement: 手順 3、 1の画像 1
    • Using a Phillips screwdriver, remove the eleven screws securing the BPS top and front metal covers.
    • If the BPS contains a one-hour battery, only the four screws holding the one-hour battery shield (four on the top cover) need to be removed.
    • Pull the covers away from the BPS.
  4. Puritan Bennett 840 BPS Battery Replacement: 手順 4、 3の画像 1 Puritan Bennett 840 BPS Battery Replacement: 手順 4、 3の画像 2 Puritan Bennett 840 BPS Battery Replacement: 手順 4、 3の画像 3
    • Locate the battery indicator bracket.
    • Cut the zip tie connecting the battery harness (bundle of wires coming from the battery) to the battery indicator bracket.
    • If the ventilator contains a one-hour battery, simply disconnect the battery harness from the battery cable and lift the battery out of the BPS.
  5. Puritan Bennett 840 BPS Battery Replacement: 手順 5、 1の画像 1
    • Use a Phillips screwdriver to remove the two screws securing the battery retaining bracket to the rear of the BPS.
  6. Puritan Bennett 840 BPS Battery Replacement: 手順 6、 1の画像 1
    • Disconnect the battery connector from J2 on the circuit board next to the battery indicator bracket.
  7. Puritan Bennett 840 BPS Battery Replacement: 手順 7、 1の画像 1
    • Using a Phillips screwdriver, loosen the two side screws and the two base screws holding the BPS front bracket.
    • Carefully lift the battery out of the BPS.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Olivia May
メンバー登録日: 01/23/20
606 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S7-G4, Paton Spring 2020 Cal Poly, Team S7-G4, Paton Spring 2020人のメンバー
CPSU-PATON-S20S7G4
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 38
今までの合計 1,066
