はじめに
If the Y-axis bearings in your PRUSA i3 MK3 are worn and need to be replaced they might make noise and prevent the heat bed from moving smoothly. If you need to replace the Y-axis bearings in your PRUSA i3 MK3, follow the steps in this guide. Ensure that you do not lose any of the parts or screws that are removed during replacement.
必要な工具と部品
Orient the printer so that the screen is facing to the left.
Using the On/Off button, switch the printer into the Off position.
Ensure your printer is off by visually inspecting the screen. If the screen is not lit up, your printer is off.
To reassemble your device, follow these instructions in reverse order. Use Step 9 for reference.
