メインコンテンツにスキップ
Protocol Kaptur GPS Main Circuit Board Replacement
必要な工具と部品
  1. Protocol Kaptur GPS Main Circuit Board Replacement, Battery: 手順 1、 2の画像 1 Protocol Kaptur GPS Main Circuit Board Replacement, Battery: 手順 1、 2の画像 2
    • The battery is accessible through the back of the drone.
    • Press the tabs on both sides of the white stripe to pull the battery out.
  2. Protocol Kaptur GPS Main Circuit Board Replacement: 手順 2、 3の画像 1 Protocol Kaptur GPS Main Circuit Board Replacement: 手順 2、 3の画像 2 Protocol Kaptur GPS Main Circuit Board Replacement: 手順 2、 3の画像 3
    • Remove the screws starting with the three smaller ones on the top part of the battery.
    • Remove the three screws on the other side.
    • There are two screws tucked under where the yellow circle is located. You will need to remove the other screws first before you get to these two.
    • There should be one 7 mm Phillips head screw, three 6 mm Phillips head screws, and four 5 mm Phillips head screws.
  3. Protocol Kaptur GPS Main Circuit Board Replacement: 手順 3、 2の画像 1 Protocol Kaptur GPS Main Circuit Board Replacement: 手順 3、 2の画像 2
    • Remove the top piece, and gently pry the two halves apart. Divide the sticker if necessary.
  4. Protocol Kaptur GPS Main Circuit Board Replacement: 手順 4、 2の画像 1 Protocol Kaptur GPS Main Circuit Board Replacement: 手順 4、 2の画像 2
    • The battery is now removable from its container.
    • During reassembly, make sure the outlet is returned to its holder and faces the correct direction.
  5. Protocol Kaptur GPS Main Circuit Board Replacement, Main Circuit Board: 手順 5、 2の画像 1 Protocol Kaptur GPS Main Circuit Board Replacement, Main Circuit Board: 手順 5、 2の画像 2
    • Remove the 4x 7mm screws on the top and bottom, and the 2x 5mm screws from the middle, then remove the back part of the housing.
    • Remove the two hidden screws at the bottom, and the white power button.
    • There will be 6x 7 mm Phillips head screws, and 2x 5 mm Phillips head screws.
  6. Protocol Kaptur GPS Main Circuit Board Replacement: 手順 6、 3の画像 1 Protocol Kaptur GPS Main Circuit Board Replacement: 手順 6、 3の画像 2 Protocol Kaptur GPS Main Circuit Board Replacement: 手順 6、 3の画像 3
    • Unplug all the cords from the circuit boards.
    • Carefully slide the main body right off the arms.
  7. Protocol Kaptur GPS Main Circuit Board Replacement: 手順 7、 2の画像 1 Protocol Kaptur GPS Main Circuit Board Replacement: 手順 7、 2の画像 2
    • Remove the four 4mm Phillips screws.
    • Desolder all cords on the circuit board, and pull the board up and out.
    • It is important to keep track of where the leads came from. Red/Blue and Black/White pairings belong to motors, whereas Black/Red pairings belong to lights. The ports are labeled on the board.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Connor Woitte
メンバー登録日: 02/15/18
858 ポイント
3のガイドは作成済み
チーム
UW Stout, Team S8-G6, Ogden Spring 2018 UW Stout, Team S8-G6, Ogden Spring 2018人のメンバー
UWSTOUT-OGDEN-S18S8G6
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 5
今までの合計 814
