はじめに
Use this guide to access and replace the main circuit board of the Protocol Kaptur GPS drone.
You can also use this guide to replace the battery: Protocol Kaptur GPS Battery Replacement.
必要な工具と部品
The battery is accessible through the back of the drone.
Press the tabs on both sides of the white stripe to pull the battery out.
Remove the 4x 7mm screws on the top and bottom, and the 2x 5mm screws from the middle, then remove the back part of the housing.
Remove the two hidden screws at the bottom, and the white power button.
ある他の人がこのガイドを完成しました。
