メインコンテンツにスキップ
Protocol Galileo Stealth Motor Replacement
必要な工具と部品
  1. Protocol Galileo Stealth Motor Replacement, Propeller: 手順 1、 1の画像 1
    • Remove the chrome shaft cover by lightly pulling it away from the drone.
  2. Protocol Galileo Stealth Motor Replacement: 手順 2、 1の画像 1
    • Using a Phillips #000 screwdriver, remove the 7mm screw from the propeller stop.
    • Be sure to apply adequate pressure when removing the screw to prevent stripping it out.
  3. Protocol Galileo Stealth Motor Replacement: 手順 3、 1の画像 1
    • Remove the propeller stop from shaft by lightly pulling it away from the drone.
  4. Protocol Galileo Stealth Motor Replacement: 手順 4、 1の画像 1
    • Remove the propeller from shaft by lightly pulling it away from the drone.
  5. Protocol Galileo Stealth Motor Replacement, Housing: 手順 5、 2の画像 1 Protocol Galileo Stealth Motor Replacement, Housing: 手順 5、 2の画像 2
    • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Take care to place the screws in a safe place to prevent losing them.
  6. Protocol Galileo Stealth Motor Replacement: 手順 6、 1の画像 1
    • Separate the upper and lower housing units by lightly pulling the two housing units apart.
  7. Protocol Galileo Stealth Motor Replacement, Motor: 手順 7、 2の画像 1 Protocol Galileo Stealth Motor Replacement, Motor: 手順 7、 2の画像 2
    • Remove the 3 outer 8mm long Phillips #0 screws from the lower drone housing.
    • Remove the 2 inner 3 mm long Phillips #0 screws from the drone motor.
    • Place screws in a safe place to prevent misplacing them.
  8. Protocol Galileo Stealth Motor Replacement: 手順 8、 1の画像 1
    • Remove the two 6mm long Phillips #0 screws from the lower motor cover located on the underside of the drone.
    • Place the screws in a safe place to prevent misplacing them.
  9. Protocol Galileo Stealth Motor Replacement: 手順 9、 1の画像 1
    • Remove the motor cover by lightly pulling it away from the drone.
  10. Protocol Galileo Stealth Motor Replacement: 手順 10、 2の画像 1 Protocol Galileo Stealth Motor Replacement: 手順 10、 2の画像 2
    • Unclip the wire plug by applying light pressure to the wire plug with the plastic opening tool, and remove the motor.
    • This plug can be a bit difficult to remove, but it does not require much force to remove.
    • Avoid damaging the plug and wires when unclipping wire plug.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Matthew Selting
メンバー登録日: 02/15/18
432 ポイント
4のガイドは作成済み
チーム
UW Stout, Team S8-G4, Ogden Spring 2018 UW Stout, Team S8-G4, Ogden Spring 2018人のメンバー
UWSTOUT-OGDEN-S18S8G4
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 15
今までの合計 1,129
