メインコンテンツにスキップ
Protocol Galileo Stealth Battery Replacement
  1. Protocol Galileo Stealth Battery Replacement, Battery: 手順 1、 1の画像 1
    • Locate the door to the battery compartment on the underside of the drone.
  2. Protocol Galileo Stealth Battery Replacement: 手順 2、 1の画像 1
    • Open the door to the battery compartment by pressing in the clip on the door and carefully lifting until the door is fully open.
  3. Protocol Galileo Stealth Battery Replacement: 手順 3、 1の画像 1
    • First pull out the wires located to the side of the battery.
    • Carefully remove the battery from the battery compartment
    • The battery can be a bit difficult to remove, but if the wires are held firmly to the battery, the battery will eventually come out by lightly pulling on the battery and wires simultaneously.
    • The small black and white wire with the white plug will not be connected to the drone, just be sure the plug does not get stuck in the battery compartment and damaged while removing the battery. This is rarely an issue.
  4. Protocol Galileo Stealth Battery Replacement: 手順 4、 1の画像 1
    • Disconnect the two ends of the wires by lightly pulling them apart.
終わりに
作成者
3人の作成者と共同で作成されました。
stephen R masalewicz
メンバー登録日: 02/15/18
270 ポイント
2のガイドは作成済み
チーム
UW Stout, Team S8-G4, Ogden Spring 2018 UW Stout, Team S8-G4, Ogden Spring 2018人のメンバー
UWSTOUT-OGDEN-S18S8G4
4 メンバー
6のガイドは作成済み
コメント 1 件
Please were can buy the battery
odoffin Kehinde - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 24
今までの合計 631
