はじめに
This is how to remove and replace the HD camera on the underside of the drone if necessary. Be careful not to pull on the wires as that may damage them. Removing the landing gear closest to the camera wires will make this job easier. Please use a clean and well lit area, as the screws are small.
必要な工具と部品
Use the fine edged plastic opening tool to pull up one side of the plug, and then the other, until it comes loose.
ある他の人がこのガイドを完成しました。
