メインコンテンツにスキップ
Protocol Dronium III AP Camera Replacement
必要な工具と部品
  1. Protocol Dronium III AP Camera Replacement, Drone Battery Pack: 手順 1、 2の画像 1 Protocol Dronium III AP Camera Replacement, Drone Battery Pack: 手順 1、 2の画像 2
    • Ensure the drone is powered off.
    • Press in and lift battery compartment cover.
    • A soft pry tool may be used for easier access.
  2. Protocol Dronium III AP Camera Replacement: 手順 2、 1の画像 1
    • Remove battery pack from body of drone.
  3. Protocol Dronium III AP Camera Replacement: 手順 3、 2の画像 1 Protocol Dronium III AP Camera Replacement: 手順 3、 2の画像 2
    • Disconnect white connectors between the battery pack and drone.
  4. Protocol Dronium III AP Camera Replacement, Camera: 手順 4、 1の画像 1
    • Remove the eight (8) 5mm screws attaching the motor arms to the body using a JIS #00 screwdriver.
  5. Protocol Dronium III AP Camera Replacement: 手順 5、 2の画像 1 Protocol Dronium III AP Camera Replacement: 手順 5、 2の画像 2
    • Remove the six (6) 5mm screws attaching the Body Cover to the Body of the drone using a JIS #00 screwdriver.
    • Remove the Body Cover.
  6. Protocol Dronium III AP Camera Replacement: 手順 6、 2の画像 1 Protocol Dronium III AP Camera Replacement: 手順 6、 2の画像 2
    • Remove the two (2) 5mm screws attaching the Motherboard to the body of the drone using a JIS #00 screwdriver.
    • Lift the Motherboard off the mounting position.
    • Do not pull hard on the Motherboard as solder connections are fragile.
  7. Protocol Dronium III AP Camera Replacement: 手順 7、 1の画像 1
    この手順で使用する道具:
    • Remove the tape covering the camera with the tweezers.
  8. Protocol Dronium III AP Camera Replacement: 手順 8、 2の画像 1 Protocol Dronium III AP Camera Replacement: 手順 8、 2の画像 2
    • Remove the plastic holding the ribbon cable connector with the tweezers.
    • Be careful with the ribbon cable, it is easy to damage.
  9. Protocol Dronium III AP Camera Replacement: 手順 9、 1の画像 1
    • Move the ribbon cable out of the way with the Spuger.
  10. Protocol Dronium III AP Camera Replacement: 手順 10、 2の画像 1 Protocol Dronium III AP Camera Replacement: 手順 10、 2の画像 2
    • Remove the camera by gently prying it out of the bracket with the spudger.
終わりに
作成者
5人の作成者と共同で作成されました。
Steven Mooers
メンバー登録日: 10/18/17
401 ポイント
4のガイドは作成済み
チーム
UW Tacoma, Team S1-G1, Rose Fall 2017 UW Tacoma, Team S1-G1, Rose Fall 2017人のメンバー
UWT-ROSE-F17S1G1
4 メンバー
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 371
