はじめに
In this guide you will learn how to remove and replace the top two propellor blades of the Gyro-X. This is a common procedure, because crashing your Gyro-X will often result in propellor damage. To remove the propellors you will only need to remove 4 small screws. Be careful not to lose these after removal.
必要な工具と部品
Place the tweezers on the sides of the links and pull straight away from the top point of connection.
ある他の人がこのガイドを完成しました。
