はじめに
In this guide you will learn how to remove and replace the top two propellor blades of the Gyro-X. This is a common procedure, because crashing your Gyro-X will often result in propellor damage. To remove the propellors you will only need to remove 4 small screws. Be careful not to lose these after removal.
必要な工具と部品
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
