はじめに
This guide will help you to replace the joysticks in the remote controller for your Gyro-X. You may need to do this if you dropped the remote and broke or jammed the joysticks. The many screws holding the remote case together are set deep in the case, so you will need a long, narrow screw driver to remove them.
必要な工具と部品
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
