メインコンテンツにスキップ
ProntoTec Axius Battery Replacement
必要な工具と部品
  1. ProntoTec Axius Battery Replacement, Battery: 手順 1、 1の画像 1
    • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
    • Place the tablet face-up on a flat table
  2. ProntoTec Axius Battery Replacement: 手順 2、 1の画像 1
    • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
    • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
  3. ProntoTec Axius Battery Replacement: 手順 3、 1の画像 1
    • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
    • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
  4. ProntoTec Axius Battery Replacement: 手順 4、 1の画像 1
    • Using a spudger remove all the tapes that touches the battery.
    • Be careful not to cute any wires that are under the tapes
  5. ProntoTec Axius Battery Replacement: 手順 5、 1の画像 1
    • Using a soldering iron, heat up the contact point of the red wire from the battery and the motherboard.
    • When the solder begins to melt, use pliers to gently pull the wire from the motherboard
    • Don't leave the soldering iron too long on top of the wire so it doesn't melt any other component in the motherboard or surrounding the area.
  6. ProntoTec Axius Battery Replacement: 手順 6、 1の画像 1
    • Repeat Step 5 on the black wire connecting the battery to the motherboard as shown in the photo.
  7. ProntoTec Axius Battery Replacement: 手順 7、 2の画像 1 ProntoTec Axius Battery Replacement: 手順 7、 2の画像 2
    • Using a spudger, gently pry the battery from the back of the screen to remove it from the device.
終わりに
作成者
4人の作成者と共同で作成されました。
Antonio Irons
メンバー登録日: 10/20/16
441 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 5-3, Martin Fall 2016 UMass Dartmouth, Team 5-3, Martin Fall 2016人のメンバー
UMASSD-MARTIN-F16S5G3
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 319
