メインコンテンツにスキップ
Professional Series PS77401 Toaster Solenoid Replacement
必要な工具と部品
  1. Professional Series PS77401 Toaster Solenoid Replacement, Shell: 手順 1、 1の画像 1
    • Make sure that the toaster is unplugged before attempting any sort of disassembly!
  2. Professional Series PS77401 Toaster Solenoid Replacement: 手順 2、 2の画像 1 Professional Series PS77401 Toaster Solenoid Replacement: 手順 2、 2の画像 2
    • Grip the black plastic lever nub firmly and carefully remove it from the metal lever. Use one hand to hold the toaster in place while you pull the lever nub with the other.
    • If this is the first time detaching this piece, it will take some effort to remove. Be careful as pulling too hard can cause damage to the inner lever mechanism.
  3. Professional Series PS77401 Toaster Solenoid Replacement: 手順 3、 3の画像 1 Professional Series PS77401 Toaster Solenoid Replacement: 手順 3、 3の画像 2 Professional Series PS77401 Toaster Solenoid Replacement: 手順 3、 3の画像 3
    • Flipping the toaster upside down, use a T7 Torx Screwdriver to remove the four 10mm screws that keep the outer shell attached.
    • Flip the toaster back over and slide off the shell making sure to slip the toaster lever (now without the black plastic nub) through the lever opening in the shell.
    • The outer shell should now only be connected by its internal wiring.
  4. Professional Series PS77401 Toaster Solenoid Replacement: 手順 4、 2の画像 1 Professional Series PS77401 Toaster Solenoid Replacement: 手順 4、 2の画像 2
    • Locate and remove the two 8mm screws that attach the circuit board (located inside of the shell) from the shell itself using the Phillips #2 screwdriver.
    • The shell should now be completely separated from the rest of the toaster.
  5. Professional Series PS77401 Toaster Solenoid Replacement, Toaster Solenoid: 手順 5、 2の画像 1 Professional Series PS77401 Toaster Solenoid Replacement, Toaster Solenoid: 手順 5、 2の画像 2
    • Locate the metal knob protruding from the removed circuit board.
    • Remove the 10mm nut with an equally sized wrench and replace the now removable solenoid.
    I'm not too sure about the meaning of the word "solenoid" here. I think what is removed is the potentiometer.
    The solenoid or electro-magnet is the yellow element that we see hanging from a red cable on the last picture.
    Or am I mistaken??!!
    Cris - 返信
終わりに
作成者
1人の作成者と共同作成されました。
Jacob M Bassetti
メンバー登録日: 01/24/14
113 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 10-36, Maness Winter 2014 Cal Poly, Team 10-36, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S10G36
4 メンバー
5のガイドは作成済み
2 件のコメント
That’s not a solenoid, that’s a potentiometer. And it’s probably soldered in so you would need to desolder it and solder in a new one, if you could find the part.
Stewart - 返信
So. . . 1) Is this a potentiometer (variable resistor) or a solenoid? Seeing that it looks like it is connected to the toaster dial for depth of "toastness", it seems like a variable resistor (but I am not an expert), 2) Either way, what is the normal Ohm reading for this device? 3) How does one test the potentiometer? Can such test be done while installed in the toaster or must the variable resistor be completely removed from the toaster before testing testing?
Bob Gordon - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 12
今までの合計 1,990
