メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Professional Series PS77401 Lever Spring Replacement
必要な工具と部品
    1. Professional Series PS77401 Lever Spring Replacement, Shell: 手順 1、 1の画像 1
      • Make sure that the toaster is unplugged before attempting any sort of disassembly!
      FixBotに聞いてみる
      コメントを追加
    2. Professional Series PS77401 Lever Spring Replacement: 手順 2、 2の画像 1 Professional Series PS77401 Lever Spring Replacement: 手順 2、 2の画像 2
      • Grip the black plastic lever nub firmly and carefully remove it from the metal lever. Use one hand to hold the toaster in place while you pull the lever nub with the other.
      • If this is the first time detaching this piece, it will take some effort to remove. Be careful as pulling too hard can cause damage to the inner lever mechanism.
      FixBotに聞いてみる
      コメントを追加
    3. Professional Series PS77401 Lever Spring Replacement: 手順 3、 3の画像 1 Professional Series PS77401 Lever Spring Replacement: 手順 3、 3の画像 2 Professional Series PS77401 Lever Spring Replacement: 手順 3、 3の画像 3
      • Flipping the toaster upside down, use a T7 Torx Screwdriver to remove the four 10mm screws that keep the outer shell attached.
      • Flip the toaster back over and slide off the shell making sure to slip the toaster lever (now without the black plastic nub) through the lever opening in the shell.
      • The outer shell should now only be connected by its internal wiring.
      FixBotに聞いてみる
      コメントを追加
    4. Professional Series PS77401 Lever Spring Replacement: 手順 4、 2の画像 1 Professional Series PS77401 Lever Spring Replacement: 手順 4、 2の画像 2
      • Locate and remove the two 8mm screws that attach the circuit board (located inside of the shell) from the shell itself using the Phillips #2 screwdriver.
      • The shell should now be completely separated from the rest of the toaster.
      FixBotに聞いてみる
      コメントを追加
    1. Professional Series PS77401 Lever Spring Replacement, Lever Spring: 手順 5、 1の画像 1
      • Locate your damaged spring that holds the toaster lever in place.
      • The spring in the picture is not damaged.
      FixBotに聞いてみる
      コメントを追加
    2. Professional Series PS77401 Lever Spring Replacement: 手順 6、 2の画像 1 Professional Series PS77401 Lever Spring Replacement: 手順 6、 2の画像 2
      • Disconnect the bottom part of the damaged spring from the lever first.
      • Then disconnect the top part of the damaged spring from the chassis.
      FixBotに聞いてみる
      コメントを追加
    3. Professional Series PS77401 Lever Spring Replacement: 手順 7、 2の画像 1 Professional Series PS77401 Lever Spring Replacement: 手順 7、 2の画像 2
      • Attach the new spring in the same spots that the damaged spring was removed from.
      • Check to make sure that the new spring allows the lever to move down with slight resistance and that it pops back up after being released.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
David Acosta
メンバー登録日: 01/24/14
125 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 10-36, Maness Winter 2014 Cal Poly, Team 10-36, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S10G36
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 49
今までの合計 2,109
