必要な工具と部品
Turn off your Laptop and open the Lid so that you can access all sides of the Monitor
Lay the Screen gently on the Keyboard of the Laptop and unplug the Display Cable
To unplug the cable you need to pull up the adhesive Foil and lift the little Lever which secures the Display Cable
Remove the old screen
Place the new Screen on the keyboard and align it with the Display Cable
Slide the Cable in the Connector and secure it with the Lever and the adhesive foil
Place the new Screen on the Little Plastic nobs and Screw it in using the old srews
After that place the Plastic cover on Top and gently Press in around the side
Turn on the Laptop and check if the Screen is Working. If not go through the Steps again
4 の人々がこのガイドを完成させました。
