メインコンテンツにスキップ
Problem with navigation in the Android System Recovery menu
ビデオの概要
  1. Problem with navigation in the Android System Recovery menu, Problem with navigation in the Android System Recovery menu: 手順 1、 3の画像 1 Problem with navigation in the Android System Recovery menu, Problem with navigation in the Android System Recovery menu: 手順 1、 3の画像 2 Problem with navigation in the Android System Recovery menu, Problem with navigation in the Android System Recovery menu: 手順 1、 3の画像 3
    • Open the Android System Recovery menu.
    • You can find the manual how to do this here.
    • If your tablet is stuck on the Android robot with exclamation mark picture, press the Volume Up or Down button.
    • Now, if the cursor is on "reboot system now", press the Volume Down key twice to go to "apply update from external storage", and just once to go to "wipe data...".
    • The cursor will stay on "apply update..." but the real selection will be "wipe data / factory reset".
    • Press the Power On button to select it. In the next menu you must choose "Yes - erase all user data".
    • Use the same technique to choose it. And finally, "reboot system now".
    No volume buttons and home button wont navigate
    Joy - 返信
  2. Problem with navigation in the Android System Recovery menu: 手順 2、 2の画像 1 Problem with navigation in the Android System Recovery menu: 手順 2、 2の画像 2
    • If the cursor is on "Apply update from ADB", press the Volume Down key twice to go to "wipe data/factory reset" and choose it with the Power On button.
    • On the next screen press press the Volume Down 3x to go steb before "Yes --delete all user data".
    • Press another one time the Volume down button. The cursor will not move, but actually you are on the "Yes -- delete all user data" and you can select it with the Power On button.
    • Did you do it successfully?
終わりに
35 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
ZFix
メンバー登録日: 12/09/13
191,278 ポイント
330のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,526のガイドは作成済み
13 件のコメント
When i factory reset through the Android system recovery menu, i can't navigate normally.
I fix it now,thank you very much!
AndroidDataRecovery - 返信
Fix all data. System
Macky Villanueva -
I can't do it it just does up with a different thing
irirangihammond - 返信
Wow I did not know this.ill try this way and thanks for the benifit
issammax147 - 返信
I got to the page where I gave to select yes but it jumps 2 spaces up and down and jumps past the yes option. How can I do it
Brittany - 返信
This is a great post. Helped me easily navigate the recovery menu on my bricked phone.
fsmanchies - 返信
By contrast, i still like to using the recovery tool to restore lost files from Android phone ,it can scan some of deleted photos from my Android SD card,http://www.android-rescuer.com/recover-d...
Tamster - 返信
Yes it worked thank you
Jesse Brook - 返信
Thanks for sharing so many interesting technical articles. I have read most of them and gain lots knowledge. And I want to share some technical articles with your reader. And I also know a good tool do well in navigation in the Android phones, or you can just search on Google with FoneDog for more detail.
Agle - 返信
doesn’t work for me please help me!
Bruce LUI - 返信
That was exactly my problem !! And I followed your steps and it worked very well, thanks a lot
Safa Fituri - 返信
Mine still gets stuck on the T-Mobile boot screen.
AlwaysAStudent - 返信
J'ai oublié mot de passe tablette Samsung A7 à l'aide
Tulipe 64 Bouquet - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 44
今までの合計 74,286
