メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Problem with navigation in the Android System Recovery menu
ビデオの概要
  1. Problem with navigation in the Android System Recovery menu, Problem with navigation in the Android System Recovery menu: 手順 1、 3の画像 1 Problem with navigation in the Android System Recovery menu, Problem with navigation in the Android System Recovery menu: 手順 1、 3の画像 2 Problem with navigation in the Android System Recovery menu, Problem with navigation in the Android System Recovery menu: 手順 1、 3の画像 3
    • Open the Android System Recovery menu.
    • You can find the manual how to do this here.
    • If your tablet is stuck on the Android robot with exclamation mark picture, press the Volume Up or Down button.
    • Now, if the cursor is on "reboot system now", press the Volume Down key twice to go to "apply update from external storage", and just once to go to "wipe data...".
    • The cursor will stay on "apply update..." but the real selection will be "wipe data / factory reset".
    • Press the Power On button to select it. In the next menu you must choose "Yes - erase all user data".
    • Use the same technique to choose it. And finally, "reboot system now".
  2. Problem with navigation in the Android System Recovery menu: 手順 2、 2の画像 1 Problem with navigation in the Android System Recovery menu: 手順 2、 2の画像 2
    • If the cursor is on "Apply update from ADB", press the Volume Down key twice to go to "wipe data/factory reset" and choose it with the Power On button.
    • On the next screen press press the Volume Down 3x to go steb before "Yes --delete all user data".
    • Press another one time the Volume down button. The cursor will not move, but actually you are on the "Yes -- delete all user data" and you can select it with the Power On button.
    • Did you do it successfully?
終わりに
36 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
ZFix
メンバー登録日: 12/09/13
196,015 ポイント
330のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
329 メンバー
1,452のガイドは作成済み
13件のガイドコメント
When i factory reset through the Android system recovery menu, i can't navigate normally.
I fix it now,thank you very much!
AndroidDataRecovery - 返信
Fix all data. System
Macky Villanueva -
I can't do it it just does up with a different thing
irirangihammond - 返信
Wow I did not know this.ill try this way and thanks for the benifit
issammax147 - 返信
I got to the page where I gave to select yes but it jumps 2 spaces up and down and jumps past the yes option. How can I do it
Brittany - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 29
過去 30 日: 74
今までの合計 75,466
