はじめに
Follow this guide to remove or replace the vacuum motor on your Presto Carpet Extractor 9.840-068.0 (2016).
Be sure to thoroughly clean and dry your extractor before you begin.
必要な工具と部品
If it is still attached, pull and disconnect the brass quick-connect fitting from the carpet extractor body.
Unclasp and release the two black latches on either side of the carpet extractor.
Use a Phillips #2 screwdriver to remove the two 1/2" screws and washers securing the vacuum motor retainer.
Gently pull the vacuum motor up and out of the extractor housing and lay it on its side.
5 の人々がこのガイドを完成させました。
