はじめに
Bypassing the valve and relieving tank pressure are crucial if you want to perform any maintenance or physical inspections of internal components... unless you want a cold shower and flooded basement.
Locate the RED bypass knobs.
Using an allan key or a pair of pliers, turn the knobs so the stamped arrows are facing each other.
CAUTION: The bypass knobs may become detached, if this happens take note of the position of the knob and return the knob to that position and press down to reseat it.
Press and hold any button for approximately 3 seconds to skip ahead, do this until the valve is in either BACKWASH or RINSE.
Wait until the time begins to count down to ensure it is has relieved pressure
Note: If you have a Downflow valve or are using this valve on a filter your first regeneration cycle will be BACKWASH, you won't need to skip ahead.
Note: The valve may take a couple of minutes to move between cycles, please be patient with it.
Your valve is now bypassed and pressure has been released, you may now perform any maintenance or inspections to your heart's content.
