はじめに
When the fan does not work when it is connected tot the wall, an incomplete power circuit connection or the regulator is most likely to cause disfunction. In this repair guide, we will open the fan until the point that all components are accessible. If the transformer is not causing the problem you will be able to inspect all components visually.
必要な工具と部品
Open up the cap of the ventilator by turning the clips on the side outwards.
Remove the screw on the bottom.
もう少しです!
終わりに
