メインコンテンツにスキップ
PowerShot G7 X Mark II LCD Screen Replacement
必要な工具と部品
  1. PowerShot G7 X Mark II LCD Screen Replacement, LCD Screen: 手順 1、 1の画像 1
    • Use a Philips #000 screwdriver to remove the three 2mm screws on the bottom of the LCD screen.
  2. PowerShot G7 X Mark II LCD Screen Replacement: 手順 2、 1の画像 1
    • Tilt the LCD screen all the way up and use a Phillips #000 screwdriver to remove the three 4mm screws from the back of the LCD screen.
  3. PowerShot G7 X Mark II LCD Screen Replacement: 手順 3、 1の画像 1
    • Remove Back panel from LCD screen.
    • Use a spudger tool to release ribbon cable from the ZIF connector.
    • The cable is thin and delicate. Detach with care.
  4. PowerShot G7 X Mark II LCD Screen Replacement: 手順 4、 1の画像 1
    • The screen is detached and can now be replaced.
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Brandon
メンバー登録日: 02/15/17
602 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 12-3, Eyestone Spring 2017 USF Tampa, Team 12-3, Eyestone Spring 2017人のメンバー
USFT-EYESTONE-S17S12G3
3 メンバー
4のガイドは作成済み
4 件のコメント
Are there any problems with the replacement screen? It’s a touch screen, just making sure the functionality of the screen is still intact.
Andrew Baez - 返信
These directions do not give enough information. The screed is glued into the frame. The replacement parts do not come with the circuit board.
alan saltus - 返信
Did you successfully replace the screen? I took off the screws, and got to the detaching the wire stage but then discovered as you said “the glue”. Any further insight would be appreciated!
rachelkernali -
My G7X lost one of the 2 screws holding the screen: do you know where I can find them?
paolofarinella - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 8
過去 30 日: 67
今までの合計 8,034
