メインコンテンツにスキップ
PowerLead Puto PLD003 Lens Replacement
必要な工具と部品
  1. PowerLead Puto PLD003 Lens Replacement, Side Panel: 手順 1、 1の画像 1
    • Slide the battery eject button open to release the battery door.
  2. PowerLead Puto PLD003 Lens Replacement: 手順 2、 1の画像 1
    • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
  3. PowerLead Puto PLD003 Lens Replacement: 手順 3、 1の画像 1
    • Rotate the camera so that the underside is facing up.
    • Remove the four 5 mm Phillips #1 screws.
  4. PowerLead Puto PLD003 Lens Replacement: 手順 4、 1の画像 1
    • Place the camera on a flat surface, with its underside facing you.
    • Gently pull up on the side panel to remove it from the camera.
  5. PowerLead Puto PLD003 Lens Replacement, Lens: 手順 5、 2の画像 1 PowerLead Puto PLD003 Lens Replacement, Lens: 手順 5、 2の画像 2
    • Remove the three 4 mm Phillips #1 screws holding the weight.
    • Remove the weight.
  6. PowerLead Puto PLD003 Lens Replacement: 手順 6、 1の画像 1
    • Remove the two 4 mm Phillips #1 screws holding the back panel in place.
  7. PowerLead Puto PLD003 Lens Replacement: 手順 7、 1の画像 1
    • Apply pressure to the back panel (away from the camera) to remove.
  8. PowerLead Puto PLD003 Lens Replacement: 手順 8、 1の画像 1
    • Set aside back panel for now.
    • Remove the final 4 mm Phillips #1 screw holding the screen in place. It is very small and hard to see.
  9. PowerLead Puto PLD003 Lens Replacement: 手順 9、 1の画像 1
    • Carefully apply pressure, away from the camera, to the screen to detach it from the body.
    • The white cord should still be connected to the body.
    • OPTIONAL: Remove the screen to make accessing the lens easier
  10. PowerLead Puto PLD003 Lens Replacement: 手順 10、 1の画像 1
    • Unscrew the two 4 mm Phillips #1 screws holding onto the lens casing
    • There are also two 4 mm Phillips #1 screws on the other side holding onto the lens casing, remove them as well.
  11. PowerLead Puto PLD003 Lens Replacement: 手順 11、 1の画像 1
    • Pull forward on the lens casing to remove it. The cord connecting the light to the motherboard should still be attached.
  12. PowerLead Puto PLD003 Lens Replacement: 手順 12、 1の画像 1
    • Unscrew the three 4 mm Phillips #1 screws holding the plastic lens holder.
  13. PowerLead Puto PLD003 Lens Replacement: 手順 13、 1の画像 1
    • Remove the plastic lens holder.
  14. PowerLead Puto PLD003 Lens Replacement: 手順 14、 1の画像 1
    • Push the lens out of the plastic casing from the back.
    • Insert new lens into the plastic casing.
終わりに
作成者
2人の作成者と共同で作成されました。
Justin Tew
メンバー登録日: 03/31/16
767 ポイント
7のガイドは作成済み
チーム
Eastern Washington University, Team 1-2, Giguere Spring 2016 Eastern Washington University, Team 1-2, Giguere Spring 2016人のメンバー
EWU-GIGUERE-S16S1G2
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 5
今までの合計 145
