メインコンテンツにスキップ
はじめに
How to remove the hard drive, along with its cable and bracket from your computer.
パーツ
パーツは指定されていません。
    • Turn the G4 over.
    • Remove the eight T8 Torx screws from the lower case.
  1. Using your thumbs, slide the lower case away from you.
    • Using your thumbs, slide the lower case away from you.
    • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  2. Your laptop should look approximately like this.
    • Your laptop should look approximately like this.
  3. iPhone X用修理キット
    Warranty up? No worries, we’ve got the fix.
    ショップを見る
    iPhone X用修理キット
    ショップを見る
  4. Skip this step if your computer does not have an Airport card.
    • Skip this step if your computer does not have an Airport card.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
    • Disconnect the antenna cable from the left side of the Airport card.
  5. Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger, removing tape as necessary.
    • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger, removing tape as necessary.
  6. To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
    • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
  7. Remove the hard drive by gently grasping the orange ribbon cable and lifting the left edge up and out of the computer.
    • Remove the hard drive by gently grasping the orange ribbon cable and lifting the left edge up and out of the computer.
    • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
  8. Your laptop should look approximately like this.
まとめ
4 の人々がこのガイドを完成させました。
添付文書
iRobot
メンバー登録日: 2009年09月24日
1 ポイント
624のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 4,986
