この翻訳は、ソースガイドの最新の更新を反映していない可能性があります。 翻訳の更新に協力してください。 または ソースガイドを参照してください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Remove the seven T8 Torx screws from the lower case.
Using your thumbs, slide the lower case toward the front of the computer.
The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
Lift the lower case off.
12 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
55%
railgunさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
添付文書
2 件のコメント
Thanks..
Great instructions.
Now to find a M6091 main battery.
does a lubricant help reduce the tension on the screen mounts. ? I read these easily break.
I lubricated my screen hinges some years ago. It did help, but I should probably do it again. I think I used a very thin silicone or aromatics WD-40 type of spray, and carefully attempted to pry open the gap of the hinge to facilitate the ingress of the lube, maybe using an Opinel knife or a Stanley blade. Apologies for flaky memory. My hinges are still a dangerously weak point, and I always open the laptop carefully and slowly with two hands. Good luck.
sqeeezy -
