この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The 56k internal modem is attached to the optical drive and standard on all models.
必要な工具と部品
Locate the battery release tab on the underside of the G4.
Slide the battery release tab to the left and lift the battery out of the computer.
Remove the seven T8 Torx screws from the lower case.
Using your thumbs, slide the lower case toward the front of the computer.
The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
Lift the lower case off.
Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
Disconnect the antenna cable from the left side of the Airport card.
Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
Remove the two T6 Torx screws from the modem.
Lift the modem off the optical drive, carefully guiding the orange ribbon cable through the space in the drive mount.
ある他の人がこのガイドを完成しました。
