メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
PowerBook G4 Titanium DVI Modem Filter Board Replacement
必要な工具と部品
    1. PowerBook G4 Titanium DVI Modem Filter Board Replacement, Battery: 手順 1、 2の画像 1 PowerBook G4 Titanium DVI Modem Filter Board Replacement, Battery: 手順 1、 2の画像 2
      • Locate the battery release tab on the underside of the G4.
      • Slide the battery release tab to the left and lift the battery out of the computer.
      FixBotに聞いてみる
      コメントを追加
    1. PowerBook G4 Titanium DVI Modem Filter Board Replacement, Keyboard: 手順 2、 1の画像 1
      • Turn the keyboard locking screw located in the middle of the keyboard so that it is parallel to the space bar. A half turn from parallel to parallel will unlock it. Another half turn will lock it again.
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      FixBotに聞いてみる
      コメントを追加
    2. PowerBook G4 Titanium DVI Modem Filter Board Replacement: 手順 3、 1の画像 1
      • Rest the keyboard face down on the trackpad area.
      • Disconnect the keyboard connector from the logic board.
      FixBotに聞いてみる
      コメントを追加
    3. PowerBook G4 Titanium DVI Modem Filter Board Replacement: 手順 4、 1の画像 1
      • Your laptop should look approximately like this.
      FixBotに聞いてみる
      コメントを追加
    1. PowerBook G4 Titanium DVI Modem Filter Board Replacement, RAM: 手順 5、 1の画像 1
      • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
      • Pull the RAM chip out.
      • Repeat this process if a second RAM chip is installed.
      FixBotに聞いてみる
      コメントを追加
    1. PowerBook G4 Titanium DVI Modem Filter Board Replacement, Lower Case: 手順 6、 2の画像 1 PowerBook G4 Titanium DVI Modem Filter Board Replacement, Lower Case: 手順 6、 2の画像 2
      • Remove the seven T8 Torx screws from the lower case.
      • Using your thumbs, slide the lower case toward the front of the computer.
      • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
      • Lift the lower case off.
      FixBotに聞いてみる
      コメントを追加
    1. PowerBook G4 Titanium DVI Modem Filter Board Replacement, Airport Card: 手順 7、 1の画像 1
      • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
      • Disconnect the antenna cable from the left side of the Airport card.
      FixBotに聞いてみる
      コメントを追加
    1. PowerBook G4 Titanium DVI Modem Filter Board Replacement, Hard Drive: 手順 8、 1の画像 1
      • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
      FixBotに聞いてみる
      コメントを追加
    2. PowerBook G4 Titanium DVI Modem Filter Board Replacement: 手順 9、 1の画像 1
      • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
      FixBotに聞いてみる
      コメントを追加
    3. PowerBook G4 Titanium DVI Modem Filter Board Replacement: 手順 10、 1の画像 1
      • Remove the hard drive by lifting the left edge up and out of the computer.
      • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
      FixBotに聞いてみる
      コメントを追加
    4. PowerBook G4 Titanium DVI Modem Filter Board Replacement: 手順 11、 1の画像 1
      FixBotに聞いてみる
      コメントを追加
    1. PowerBook G4 Titanium DVI Modem Filter Board Replacement, Optical Drive Removal: 手順 12、 1の画像 1
      • Disconnect and remove the indicated orange ribbon cable.
      FixBotに聞いてみる
      コメントを追加
    2. PowerBook G4 Titanium DVI Modem Filter Board Replacement: 手順 13、 1の画像 1
      • Disconnect the pink and white inverter cable from the inverter board.
      • The display inverter has orange plastic shielding around it that looks similar to the tape used elsewhere within the computer. Do not remove the shielding from the inverter.
      FixBotに聞いてみる
      コメントを追加
    3. PowerBook G4 Titanium DVI Modem Filter Board Replacement: 手順 14、 1の画像 1
      • Remove the two silver T8 Torx screws from the black plastic bar.
      • Lift the black plastic bar out.
      • Reassembly will be significantly easier if you reseat the hard drive before returning the black bar to its place.
      FixBotに聞いてみる
      コメントを追加
    4. PowerBook G4 Titanium DVI Modem Filter Board Replacement: 手順 15、 1の画像 1
      • Disconnect the two orange connectors from the logic board, removing tape as necessary.
      FixBotに聞いてみる
      コメントを追加
    5. PowerBook G4 Titanium DVI Modem Filter Board Replacement: 手順 16、 1の画像 1
      • Lift the drive up on the right side so that you can access and disconnect the modem cable and inverter cable.
      FixBotに聞いてみる
      コメントを追加
    6. PowerBook G4 Titanium DVI Modem Filter Board Replacement: 手順 17、 1の画像 1
      • Remove the drive by lifting the right edge up and out of the computer.
      FixBotに聞いてみる
      コメントを追加
    1. PowerBook G4 Titanium DVI Modem Filter Board Replacement, DC-In Board: 手順 18、 1の画像 1
      • Disconnect the large DC-In connector from the right side of the logic board.
      FixBotに聞いてみる
      コメントを追加
    2. PowerBook G4 Titanium DVI Modem Filter Board Replacement: 手順 19、 1の画像 1
      • Remove the two T6 Torx screws from the DC-In board.
      FixBotに聞いてみる
      コメントを追加
    3. PowerBook G4 Titanium DVI Modem Filter Board Replacement: 手順 20、 1の画像 1
      • Lift the DC-In board out of the computer by pulling up and away from you.
      • If you don't have a 667 MHz computer, there is a fan in this location which makes it a bit difficult to remove the DC-In board.
      • If there is a fan present, rotate the DC-In board slightly clockwise before easing it out at a slight angle in order to clear the fan clamp on top of it.
      FixBotに聞いてみる
      コメントを追加
    1. PowerBook G4 Titanium DVI Modem Filter Board Replacement, Modem Filter Board: 手順 21、 1の画像 1
      • Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over and place it on the cloth.
      • Disconnect the four indicated connectors from the logic board.
      • The large multicolor cable may be difficult to free.
      • The top center cable may not need to be disconnected to remove the modem filter board. It connects to the logic board fan to its immediate left, which is attached to the logic board itself.
      FixBotに聞いてみる
      コメントを追加
    2. PowerBook G4 Titanium DVI Modem Filter Board Replacement: 手順 22、 1の画像 1
      • Remove the T8 Torx screw near the heat pipe.
      FixBotに聞いてみる
      コメントを追加
    3. PowerBook G4 Titanium DVI Modem Filter Board Replacement: 手順 23、 1の画像 1
      • Disconnect the two connectors from the modem filter board.
      • To the immediate right of the modem filter board, the heatsink has two sets of five fins with a double-wide space in between them. This space is where the gray & black coiled wire is supposed to go to ensure a flush fit.
      FixBotに聞いてみる
      コメントを追加
    4. PowerBook G4 Titanium DVI Modem Filter Board Replacement: 手順 24、 1の画像 1
      • Remove the T6 Torx screw from the modem filter board.
      FixBotに聞いてみる
      コメントを追加
    5. PowerBook G4 Titanium DVI Modem Filter Board Replacement: 手順 25、 1の画像 1
      • Remove the modem filter board from the computer by pulling up and to the right.
      • There is a small plastic post which helps hold the modem filter board in place. You need to clear this post to remove the modem filter board from the computer.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
添付文書
作成者
3人の作成者と共同で作成されました。
iRobot
メンバー登録日: 09/24/09
1 ポイント
632のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 27
過去 30 日: 108
今までの合計 4,566
