はじめに
PRAM batteries on the G4 PowerBooks are an aging part causing errors with the date and time among other things. You can replace the battery with just a few simple steps.
必要な工具と部品
You will need to remove the PRAM battery assembly from your computer. Refer to our G4 PowerBook guides for how to do that specifically for your computer.
Make note of where the positive (+) side connects so to eliminate confusion when you try to install the new battery.
There are only two locations where you will need to solder.
You can now install the PRAM assembly back in the computer.
22 の人々がこのガイドを完成させました。
6 件のコメント
I posted details, and a source for the battery, over on the Powerbook G4 15” PRAM battery replacement page: PowerBook G4 Aluminum 15" 1-1.5 GHz PRAM Battery Replacement
It should be the same thing here.
david -
Be careful! Not all Powerbooks have this one battery. My 17” Powerbook G4 Aluminium has two CGL 2430. The board looks much different to the one in the above photos. The batteries are smaller (smaller diameter), and the module is longer and narrower. I just opened my Powerbook G4 to replace the battery, just to realise that I bought the wrong battery!!
Now I got confused. What PB g4 this guide refers to? I saw a Apple article saying that PB G4 12" does not have a back battery instead, it uses a capacitor to hold energy enough for you to change the main battery. Is that correct? Sorry if a missed something.
link for the article
