この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Is your PowerBook mute? Replace your speakers.
必要な工具と部品
Use your thumbs to push the two battery retaining tabs away from the battery.
The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
Remove the following ten screws:
Two 14.7 mm shouldered Phillips.
Three 12.3 mm Phillips.
One 3.8 mm T8 Torx.
One 6.8 mm T8 Torx.
Three 1.3 mm Phillips.
2 の人々がこのガイドを完成させました。
