この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Upgrade your RAM for an instant increase in speed.
必要な工具と部品
Use your thumbs to push the two battery retaining tabs away from the battery.
The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
24 の人々がこのガイドを完成させました。
