メインコンテンツにスキップ
PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement
必要な工具と部品
  1. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement, Rear Display Bezel: 手順 1、 2の画像 1 PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement, Rear Display Bezel: 手順 1、 2の画像 2
    • Remove the two 6.3 mm Phillips screws near the lower left and right corners of the display.
    • Removing these two screws may be difficult. It is helpful to open the display as much as possible for clearance to use a screwdriver. Also, a combination of #00 Phillips and small flathead screwdrivers along with a pair of tweezers may aid in removal.
    It is much safer to follow the instructions for removing the entire display (PowerBook G4 Aluminum 17" 1-1.67 GHz Display Replacement) before removing these screws by bending the display beyond its tolerances.
    amatuer6 - 返信
    I've already spent 30 mins trying to remove these screws. DO NOT attempt this unless you have plenty of time to waste. Just take the top case/keyboard off and remove the screen assembly to save yourself a big headache. Thanks for the great site.
    dwoodusa90069 - 返信
  2. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 2、 1の画像 1
    • The picture at left (rear panel already removed) shows the locations of the metal clips (shown in red) that snap on to the front display bezel. In the next few steps, you will use a small flathead screwdriver to release these clips from a ridge around the perimeter of the front display bezel.
    • When prying in the following steps, be sure not to damage the antenna cables that run around the perimeter of the front display bezel.
  3. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 3、 3の画像 1 PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 3、 3の画像 2 PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 3、 3の画像 3
    • Insert the flat end of a spudger between the rear display bezel and the plastic rim attached to the front display bezel near the lower right corner of the display.
    • Do not try to insert the spudger between the front display bezel and its plastic surround.
    • While carefully prying the rear display bezel away from the display assembly, use a small flathead screwdriver to pry the small steel clip nearest the bottom right corner of the display away from the edge of the front display bezel.
    • Repeat the above procedure until you've released all the clips along the right side of the display.
  4. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 4、 1の画像 1
    • Slightly lift the recently-freed corner of the rear display bezel to separate the clips with a spudger along the span of the clutch hinges.
  5. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 5、 2の画像 1 PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 5、 2の画像 2
    • Insert the flat end of a spudger between the rear display bezel and the plastic surround of the front display bezel near the lower left corner of the display.
    • Carefully pry the rear display bezel away from the front display bezel to expose the metal clips along the left side of the display.
    • Repeat the previous procedure to release the clips along the left side of the rear display bezel.
  6. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 6、 2の画像 1 PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 6、 2の画像 2
    • Slightly lift the lower edge of the rear display bezel and push it toward the top edge of the display, releasing the clips along the top edge of the rear display bezel.
    • Remove the rear display bezel and set it aside.
  7. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement, Display Inverter: 手順 7、 1の画像 1
    • If necessary, remove the tape covering the display inverter.
    • Carefully lift the display inverter board from the side nearest the display data cable connector.
    • The display inverter is an extremely thin circuit board that is easily broken. Do not excessively bend or twist it during removal.
  8. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 8、 2の画像 1 PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 8、 2の画像 2
    • Use your fingernails to pull the ears on both sides of the inverter cable connector away from its socket on the inverter board.
  9. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 9、 1の画像 1
    • Carefully lift the display inverter out of the clutch cover.
    • Don't try to remove the inverter just yet. It is still attached via the backlight cables.
  10. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 10、 2の画像 1 PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 10、 2の画像 2
    • Use your fingers to pull the backlight connector away from its socket on the inverter board.
    • Remove the display inverter from the display assembly.
  11. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement, LCD: 手順 11、 1の画像 1
    • If present, remove the piece of tape covering the display data cable.
  12. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 12、 1の画像 1
    • Pull the display data cable straight away from its socket on the LCD.
  13. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 13、 1の画像 1
    • Remove the four 3.2 mm Phillips screws securing the left side of the LCD assembly to the front display bezel.
  14. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 14、 2の画像 1 PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 14、 2の画像 2
    • Remove the four 3.2 mm Phillips screws from the top portion of the LCD assembly.
  15. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 15、 1の画像 1
    • Remove the four 3.2 mm Phillips screws along the right side of the display.
  16. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 16、 2の画像 1 PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 16、 2の画像 2
    • Carefully peel the protective translucent shield off the antenna board.
    • If you damage this during disassembly, be sure to tape over any tears or cracks to avoid unintended shorting.
  17. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 17、 2の画像 1 PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 17、 2の画像 2
    • Use the flat end of a spudger to pry the the antenna cables straight up off their sockets.
  18. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 18、 1の画像 1
    • Remove the single 2.5 mm Phillips screw securing the display data cable ground loop to the front display bezel.
  19. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 19、 1の画像 1
    • Remove the two 10.3 mm T8 Torx screws securing the left side of the clutch hinges to the front bezel.
  20. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 20、 1の画像 1
    • Remove the two 10.3 mm T8 Torx screws securing the center of the clutch hinges to the front bezel.
  21. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 21、 1の画像 1
    • Remove the two 10.3 mm T8 Torx screws securing the right side of the clutch hinges to the front display bezel.
  22. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 22、 1の画像 1
    • Press the display release button to release the top edge of the display from the upper case.
    • Carefully wiggle and lift the display assembly straight up off its positioning pins on the clutch hinges.
  23. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 23、 1の画像 1
    • In the following steps, you will use a heat gun to soften the adhesive securing the metal LCD frame to the front display bezel. Heat guns have the capability of producing an extremely hot jet of air, so be sure not to overheat the LCD panel.
    • With the heat gun set to low, start by heating the front display bezel near the upper left corner of the display panel.
    There really isn’t a need to use a heat gun, just gently push the screen through the frame to detach it from the bezel.
    James Dalpiaz - 返信
  24. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 24、 2の画像 1 PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 24、 2の画像 2
    • Insert a plastic opening tool between the metal LCD frame and the front bezel.
    • Be sure you are prying between the metal LCD frame and the front bezel, not between the metal LCD frame and the LCD.
    • It may be necessary to reheat this area until the adhesive yields enough to insert the edge of a tool.
    • Use the flat end of a metal spudger to gently pry up the adhesive securing the metal LCD frame to the front bezel, taking special care not to scratch the LCD panel.
  25. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 25、 1の画像 1
    • While it is still inserted between the metal LCD frame and the front bezel, run the edge of your metal spudger along the top edge of the display to separate the adhesive securing the two pieces together, heating the area you are working on with a heat gun as necessary.
    • If the adhesive is hard to separate, use a heat gun to lightly heat the area you are working on.
  26. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 26、 3の画像 1 PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 26、 3の画像 2 PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 26、 3の画像 3
    • Continue running the edge of your metal spudger between the LCD frame and the front bezel until the right, bottom, and left sides of the LCD are free.
  27. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 27、 1の画像 1
    • Lift the LCD by its top edge only. Lifting the LCD by its lower edge will damage the backlight cables.
    • Lift the LCD out of the front display bezel, using your metal spudger to release any adhesive if necessary.
  28. PowerBook G4 Aluminum 17" 1-1.67 GHz LCD Replacement: 手順 28、 1の画像 1
    • With the LCD partially removed from the front bezel, carefully push the backlight connector through its tunnel in the front bezel.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Andrew Bookholt
586,109 ポイント
619のガイドは作成済み
2 件のコメント
This is not for the faint of heart I would not recommend doing this. Over 2 hours taking it apart another 2 putting it back. No real directions as to putting it back togeather. The Basel needs to be put on the top first for it has the most clips. Take a picture of it when you get it apart so you can see how to put everything back as in the cables and wires. This has got to be the worst design ever. Also for $20 replace the inverter board at the same time, so you don't have to take it apart again.
Thomas - 返信
Do yourself a favor and remove the display assembly from the computer first.
DistroHopper39B - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 7
今までの合計 12,793
