はじめに
Replace a clutch hinge to keep your display opening smoothly.
必要な工具と部品
Use a coin or a spudger to turn the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Remove the four Phillips screws from the memory door.
Slide the memory door away from the memory compartment.
Grasp the back corners of the upper case and pull up. Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
Remove the 9.5 mm silver Phillips screw from the top of the right ambient light sensor board.
Remove the small 3 mm black Phillips screw from the bottom of the board.
Remove the two black Phillips screws from the right speaker.
Lift the speaker away from the logic board and place it aside
Grasp the logic board at the left edge with one hand and at the thinnest section with the other hand. Lift the left edge of the board up to approximately a 30 degree angle (if you don't have your protractor handy, just lift until the DVI port clears the right hinge).
Once the logic board clears the ports, slide it out to the left.
To properly reassemble your PowerBook, you'll have to clean off and replace the old thermal compound. Use our Applying Thermal Paste Guide to prepare the processor and heat sink surfaces.
Remove the two 3 mm black Phillips screws from the left ambient light sensor board.
Lift the left ambient light sensor board out of the computer, removing tape as necessary.
Remove the two 4.2 mm silver Phillips screws from the left corners of the PC card cage.
Remove the two 4.2 mm silver Phillips screws from either side of the large orange Airport ribbon.
Lift the Airport card out of the computer and slide a spudger between the card and the antenna connector to disconnect the cable from the card.
Deroute the antenna cable from the side of the card, removing tape as necessary.
You don't need to remove the Airport card entirely. We're just trying to free up the Airport antenna cable.
Remove the two 11 mm X 1.5 mm hex screws near the lower left and right corners of the display.
With your spudger still inserted under the front display bezel, run it around the lower left corner of the display.
Rotate the spudger away from yourself to pry the rear display bezel off the aluminum tabs on the front display bezel.
Work your way down the side of the display until the rear display bezel has been separated from the front display bezel.
Repeat the previous steps to separate the right side of the rear display bezel from the display.
Use your spudger to pry the plastic retaining clips on the rear display bezel over the raised aluminum tabs on the front display bezel.
At this point, the clips on the left and right edges of the rear display bezel should be free from the raised aluminum tabs on the front display bezel. If they are not, use a spudger to pry them past the front display bezel.
Use your thumbs to push the clutch cover away from the clutch hinges.
While pressing with your thumbs, rotate the clutch cover toward yourself about its long edge to pop it off the clutch hinge.
It may be necessary to wiggle the clutch cover while pressing it away from the clutch hinges to release the retaining clips.
Remove the three T8 Torx screws securing the right clutch hinge to the front bezel.
ある他の人がこのガイドを完成しました。
