メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Charges battery and connects battery to logic board.
  1. Use a coin to turn the battery locking screw 90 degrees clockwise.
    • Use a coin to turn the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. Remove the four Phillips screws from the memory door.
    • Remove the four Phillips screws from the memory door.
    • Slide the memory door away from the memory compartment.
  3. Remove the following 8 screws:
    • Remove the following 8 screws:
    • Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
    • Two 12 mm Phillips on either side of the memory compartment.
    • Four 16 mm Phillips along the hinge.
  4. Rotate the computer 90 degrees clockwise, so that the power receptacle faces you.
    • Rotate the computer 90 degrees clockwise, so that the power receptacle faces you.
    • Remove the three 3 mm Phillips screws.
    • When replacing these screws, you must place each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
  5. Turn the computer 90 degrees clockwise so that the hinge faces you.
    • Turn the computer 90 degrees clockwise so that the hinge faces you.
    • Remove the bottom 5 mm Phillips screw on either side of the hinge (two total).
  6. Rotate the computer 90 degrees clockwise, so that the ports face you.
    • Rotate the computer 90 degrees clockwise, so that the ports face you.
  7. Turn the computer over and open the display.
    • Turn the computer over and open the display.
    • Remove the two 1.5 mm hex screws in either corner, next to the display (a T6 Torx driver will work, but repeated use will strip the screws).
  8. Grasp the back corners of the upper case and pull up. Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
    • Grasp the back corners of the upper case and pull up. Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
    • Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
  9. Rotate the upper case up and toward the screen, so that the upper case rests against it.
    • Rotate the upper case up and toward the screen, so that the upper case rests against it.
  10. Remove the orange tape securing the trackpad ribbon to the logic board.
    • Remove the orange tape securing the trackpad ribbon to the logic board.
    • Disconnect the trackpad ribbon from the logic board.
    • Remove the upper case from the computer.
  11. Disconnect the sleep light cable from the logic board to gain access to the battery connector cable beneath it.
    • Disconnect the sleep light cable from the logic board to gain access to the battery connector cable beneath it.
  12. Disconnect the battery connector cable from beneath the logic board.
    • Disconnect the battery connector cable from beneath the logic board.
    • While it's easier to pull the thick battery connector cable out with your fingers, a spudger will help you push it back into place when putting the computer back together.
  13. Remove the two silver Phillips screws from the battery connector.
    • Remove the two silver Phillips screws from the battery connector.
    • Remove a third Phillips screw near the bottom left corner of the hard drive that pins down a ground loop.
    • The screws with the larger heads go on the battery connector.
  14. Lift the battery connector out of the computer, removing tape as necessary.
    • Lift the battery connector out of the computer, removing tape as necessary.
終わりに
添付文書
iRobot
メンバー登録日: 2009年09月24日
1 ポイント
648のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 5
今までの合計 7,053
