メインコンテンツにスキップ
PowerBook G4 Aluminum 12" 867 MHz Keyboard Replacement
必要な工具と部品
  1. PowerBook G4 Aluminum 12" 867 MHz Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Use a coin to turn the battery locking screw 90 degrees to the right.
    • Lift the battery out of the computer.
  2. PowerBook G4 Aluminum 12" 867 MHz Keyboard Replacement, EMI Finger: 手順 2、 1の画像 1
    • Remove the four Phillips screws from the memory door.
    • Slide the memory door away from the memory compartment.
  3. PowerBook G4 Aluminum 12" 867 MHz Keyboard Replacement: 手順 3、 1の画像 1
    • Remove the long black Phillips screw next to the memory card.
    • Remove the small EMI finger beneath the black screw.
  4. PowerBook G4 Aluminum 12" 867 MHz Keyboard Replacement, Keyboard: 手順 4、 1の画像 1
    • On the keyboard, remove the F1, F2, F11, and F12 keys.
    • This is scary - take a deep breath before continuing. Place your index finger under the upper left corner of the key and lift up until you hear a click. Then, transfer your finger to the left edge of the key and lift up to pull the key off.
    • You're freeing the two tabs on the left of the key from the two small holes in the plastic scissors mechanism.
    • When replacing the keys in the keyboard, place the key directly over the slot where it will go and press down until you hear the key click into place.
  5. PowerBook G4 Aluminum 12" 867 MHz Keyboard Replacement: 手順 5、 1の画像 1
    • Use your fingernail or a small flathead screwdriver to peel up the gray stickers covering each of the screws.
  6. PowerBook G4 Aluminum 12" 867 MHz Keyboard Replacement: 手順 6、 1の画像 1
    • Remove the two short Phillips screws.
  7. PowerBook G4 Aluminum 12" 867 MHz Keyboard Replacement: 手順 7、 1の画像 1
    • Lift the keyboard by the 'esc' and 'eject' keys and gently lift up until the keyboard is vertical.
  8. PowerBook G4 Aluminum 12" 867 MHz Keyboard Replacement: 手順 8、 1の画像 1
    • Grasp the keyboard connector ribbon near the connector and disconnect it from the logic board.
終わりに
4 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
iRobot
メンバー登録日: 09/24/09
1 ポイント
636のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 17
今までの合計 14,845
