このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Insert a plastic opening tool between the left edge of the front display bezel and the plastic strip attached to the rear bezel, with the edge of the tool angled toward the LCD.
Rotate the tool away from the LCD to pop the rear bezel off the tabs on the front display bezel.
Work along the left edge of the display until the rear bezel is evenly separated from the front bezel.
この手順は未翻訳です。 翻訳を手伝う。
Insert a plastic opening tool between the right edge of the front display bezel and the plastic strip attached to the rear bezel, with the edge of the tool angled toward the LCD.
Work along the right edge of the display until the rear bezel is evenly separated from the front bezel.
この手順は未翻訳です。 翻訳を手伝う。
Insert the pointed end of the a spudger between the protective tape and the inverter board.
Carefully pull up with the spudger to lift the inverter board out enough to access the connector cables.
Once you can easily grab the board, pull it up enough to gain access to the inverter board's output connector.
4 の人々がこのガイドを完成させました。
