はじめに
Removing the heat shield enables access to the RAM and processor beneath.
ツール
パーツ
Remove both expansion bay modules using the levers on the front of the computer.
Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
Pull the tabs toward yourself and the keyboard will pop up.
ある他の人がこのガイドを完成しました。
